Wiring for attaching Y AXIS motor does not match Assembly manual - Y axis doesn't work!
grabnerwg@gmail.com
(@grabnerwggmail-com)
I received my MINI today and spent the evening assembling. No problem, except in The Assembly manual the picture and the real wiring attached to the machine are not the same. In reality there is no four color braided cord coming out of the Y motor marked Y. Obviously a new design and old documentation. BUT in the meantime, my  Y axis doesn't work and I can't print!
I tried to connect what looked like should be connected, but no dice.
Dead in the water until I receive new documentation.
This topic was modified 6 years ago by [email protected]
Posted : 02/05/2020 6:26 am
RE: Wiring for attaching Y AXIS motor does not match Assembly manual - Y axis doesn't work!
Speak to Prusa support Chat,
24 hour service
available on the eShop page, bottom right corner, wait 5 seconds if you don't see it immediately!
regards joan
Posted : 02/05/2020 11:02 am
grabnerwg@gmail.com
Question answered and issue resolved. Thanks for the help from everybody whp responded.
Posted : 02/05/2020 5:08 pm
With_Maltodextrin
(@with_maltodextrin)
Posted by: @grabnerwg
What was the answer? It's helpful to have things like this documented on the forum to help others who end up in your same position.
Posted : 02/05/2020 9:21 pm
grabnerwg@gmail.com
The wire was invisible. Trapped between the bodies of the X, Z body and the Y body. At someone's suggestion, I turned it completely over and saw the connector protruding. I recognized it immediately as what I needed. Two minutes late it was plugged in with the rest of the electronics and I am up and printing my third object!
Posted : 03/05/2020 1:08 pm
