Uneven Bed not Leveling
fivesinatras
(@fivesinatras)
I am trying to calibrate my newly setup Mini Prusa but the bed is not at all level - I have run the selftest and it says all is ok. I did the mesh bed leveling and then went to calibrate. The nozzle is perfect on the right side but when it goes to the left it is several mm above the bed - it is too far to even be able to adjust the Z axis using the knob (even if it wasn't if I got low enough to let the left side work, the right would be much too close). No test or calibration seems to think anything is wrong but it won't print like this.
Any help is welcome! I am concerned this is an issue with the factory level, idk
Posted : 09/08/2022 8:31 pm
