Typical Z-offset values?
stwaldo
(@stwaldo)
Trying first layer calibration, and finding my z-offset is at like -0.300 - is this normal, or did I botch something? I double checked the SuperPINDA position before running calibration this morning, and it looks like it's set correctly.
Best Answer by FoxRun3D:
The max you can go on the Mini is -2.0, so -0.3 is on the low end but perfectly normal. I usually target -1.0 by adjusting the PINDA accordingly. I came up with this tool to help: https://www.printables.com/model/57192
Napsal : 18/09/2023 1:33 pm
Move the SuperPINDA by one or perhaps two threads and recalibrate to come into to the approx -1 range.  -2 is OK but that's the limit.
Napsal : 18/09/2023 3:47 pm
stwaldo se líbí
RE: Typical Z-offset values?
Napsal : 18/09/2023 4:58 pm
stwaldo se líbí
stwaldo
(@stwaldo)
Re-leveled the PINDA (and put in the correct screw to secure it for good measure - oops). Here's where I'm at around -1.1
Test pattern on a Mini+
Napsal : 18/09/2023 7:12 pm
