					                		Trying to figure out this zits or holes - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/</link>
                <lastBuildDate>Fri, 12 Jun 2026 02:10:54 +0000</lastBuildDate>
                        <title>RE: Ich versuche, diese Pickel oder Löcher herauszufinden</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420538</link>
                        <pubDate>Tue, 20 Apr 2021 19:17:54 +0000</pubDate>
                        <description><![CDATA[@sid-2Ok it&#039;s interesting to know, I know that the Prusa MINI uses 3.2mm by default, but it just didn&#039;t work because I can only use 1.4mm with no problem, but that the problem is also with t...]]></description>
                        <content:encoded><![CDATA[<p>@sid-2</p><p>Ok it's interesting to know, I know that the Prusa MINI uses 3.2mm by default, but it just didn't work because I can only use 1.4mm with no problem, but that the problem is also with the standard Prusa extruder occurs is strange because it can't be due to the hotend, because I also use the same setting when converting to V6.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Daniel</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420538</guid>
                        <title>RE: Trying to figure out this zits or holes</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420529</link>
                        <pubDate>Tue, 20 Apr 2021 19:08:12 +0000</pubDate>
                        <description><![CDATA[In my default prusa mini profile the retraction is 3.2mm. I&#039;m using the default extruder on the Prusa Mini]]></description>
                        <content:encoded><![CDATA[<p>In my default prusa mini profile the retraction is 3.2mm. I'm using the default extruder on the Prusa Mini</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Sid</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420529</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420517</link>
                        <pubDate>Tue, 20 Apr 2021 18:49:37 +0000</pubDate>
                        <description><![CDATA[@sid-2That&#039;s the problem, the retraction was too high, I have 1.4mm for PLA, do you happen to own a Bondtech extruder?And the retraction is standard for me, no matter what brand, with PETG I...]]></description>
                        <content:encoded><![CDATA[<p>@sid-2</p><p>That's the problem, the retraction was too high, I have 1.4mm for PLA, do you happen to own a Bondtech extruder?<br />And the retraction is standard for me, no matter what brand, with PETG I have 1.6mm</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-420517</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-419224</link>
                        <pubDate>Mon, 19 Apr 2021 07:36:11 +0000</pubDate>
                        <description><![CDATA[This problem is solved. I&#039;ve changed the default retraction from 3.2mm to 1.5 and prints are perfect now. All the other settings are the same. I&#039;m using eSun PLA+ filament. I would be nice t...]]></description>
                        <content:encoded><![CDATA[<p>This problem is solved. I've changed the default retraction from 3.2mm to 1.5 and prints are perfect now. All the other settings are the same. I'm using eSun PLA+ filament. I would be nice though if someone could explain why the zits are in a different location then where the retractions are. This is still a mystery to me, the only thing I could think of is because there is air sucked into the nozzle at the retraction.</p><p> </p><p>Left: 1.5mm rectraction        Right 3.2mm retraction</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210419_093324.jpg"><img class="alignnone size-medium wp-image-83470" src="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210419_093324-600x500.jpg" alt="" width="600" height="500" /></a></p><p> </p><p> </p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-419224</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417109</link>
                        <pubDate>Thu, 15 Apr 2021 22:07:33 +0000</pubDate>
                        <description><![CDATA[It might be a slight underextrusion, but first I would try printing a few degrees hotter.  Also, slowing the perimeter print speed might be gentler on the filament.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>It might be a slight underextrusion, but first I would try printing a few degrees hotter.  Also, slowing the perimeter print speed might be gentler on the filament.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417109</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417022</link>
                        <pubDate>Thu, 15 Apr 2021 19:00:30 +0000</pubDate>
                        <description><![CDATA[Same print, but now with retraction configured as 2.5mm. There&#039;s definitely improvement visible. I&#039;m wondering how much retraction other people use.]]></description>
                        <content:encoded><![CDATA[<p>Same print, but now with retraction configured as 2.5mm. There's definitely improvement visible. I'm wondering how much retraction other people use.</p><p> </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210415_205720.jpg"><img class="alignnone size-medium wp-image-82813" src="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210415_205720-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417022</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417013</link>
                        <pubDate>Thu, 15 Apr 2021 18:31:02 +0000</pubDate>
                        <description><![CDATA[Another test with a smaller print. This is the back of the print, seam is configured as aligned.]]></description>
                        <content:encoded><![CDATA[<p>Another test with a smaller print. This is the back of the print, seam is configured as aligned.</p><p> </p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210415_202912.jpg"><img class="alignnone size-medium wp-image-82810" src="https://forum.prusa3d.com/wp-content/uploads/2021/04/20210415_202912-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-417013</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416974</link>
                        <pubDate>Thu, 15 Apr 2021 16:45:04 +0000</pubDate>
                        <description><![CDATA[I&#039;ve been listening a little bit better and there are plopping noises. I&#039;ve moved the role of filament to my MK3s and there you can&#039;t hear the noise. On the Mini there seems to be regularity...]]></description>
                        <content:encoded><![CDATA[<p>I've been listening a little bit better and there are plopping noises. I've moved the role of filament to my MK3s and there you can't hear the noise. </p><p>On the Mini there seems to be regularity. After a retraction it takes about 2 seconds and then two pops come shortly after each other. So it looks like it has something to do with the retraction. It may sound strange, but could air be sucked into the nozzle?retraction settings are default.</p><p>Length: 3.2mm<br />Lift Z: 0.2mm</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416974</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416878</link>
                        <pubDate>Thu, 15 Apr 2021 13:18:36 +0000</pubDate>
                        <description><![CDATA[If it would be filament the zits wouldn&#039;t be at the same positions everything, I think. Don&#039;t hear any strange noises coming from the extruderI&#039;ve uploaded an 3mf file;]]></description>
                        <content:encoded><![CDATA[<p>If it would be filament the zits wouldn't be at the same positions everything, I think. Don't hear any strange noises coming from the extruder</p><p>I've uploaded an 3mf file; https://easyupload.io/wcpmsj</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416878</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416872</link>
                        <pubDate>Thu, 15 Apr 2021 12:56:23 +0000</pubDate>
                        <description><![CDATA[Interesting.  I originally suspected damp filament which is why I suggested the switch.Do you hear any noises from the extruder/nozzle when printing?Gcode is rarely much help.  Please zip a ...]]></description>
                        <content:encoded><![CDATA[<p>Interesting.  I originally suspected damp filament which is why I suggested the switch.</p><p>Do you hear any noises from the extruder/nozzle when printing?</p><p>Gcode is rarely much help.  Please zip a 3mf file (save project from slicer), it will contain the settings we need to diagnose this.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/trying-to-figure-out-this-zits-or-holes/#post-416872</guid>
