Super PINDA 25 minute calibration
I just upgraded my Mini to a Super-Pinda (black tip replacing orangish tip).
I remember reading somewhere that there was a precise calibration process that took 20~25 minutes and did a 1000-point calibration.
My mini continues to o 9-point calibration and doesn't indicate anything to show that it knows the PINDA is "Super"?
1) Do I need to do something to trigger the 1000 point calibration? Or is the 1000 point calibration (that takes 20~25 minutes) only for the Mk3?
2) Is there a way to confirm that the Mini knows the PINDA is "Super"?
RE: Super PINDA 25 minute calibration
1) I'm not aware of any 1000 point calibration routine on the Mini. I think the Mk 3 does 7x7 point and can do multiple 'probes' per point, so may get to 1000 points.
2) The Mini doesn't need to know what what Minda / Pinda it has fitted as it's "just" a switch. The Super Pinda is more stable across the operating temperature, so it is more consistent when calibrating.
I have fitted a Super PINDA to my Mini and there is no change to the calibration process.
The Prusa Mk3 advertises a 32x32 (1024 point calibration) with the Super-PINDA.
I had assumed the Mini did this as well.
You can find the details of the new mesh bed leveling for the Mk3 on the GitHub pages here. The new algorithm uses a 32x32 grid for a total of 1,024 test points.
I don't see an equivalent entry in the Mini pages, so can only assume the feature hasn't been rolled out for the Mini yet. They may just be using the SuperPINDA as a MINDA for now.
Woo, doing a 32x32 before every print would be rough taking a half hour pre-print time... I couldn't imagine doing that just to run small prints or something.
@seattledavid
In your opening you said 9 point, the Mini has a 4x4 - 16 point mesh bed level. The MK3 has a 3x3 - 9 point mesh by default, and a 7x7 - 49 point as an option. However, with the 7x7, 11 of the 49 are close to magnets and can throw them off, there's a magnet compensation that ignores those 11 for that reason. The new 32x32 seems a bit much, but I guess time vs REALLY level bed... I guess it's technically a shorter time than printing a safety raft.
EDIT: Checking the github, the new 32x32 is only for XYZ calibration, not the standard MBL procedure.
I think I know, I donât think I know. I donât think I think I know, I donât think I think.
