Strange separations of the filament on the print aka holes
radianrad
(@radianrad)
I’m seeing this issue on all prints and in several materials  I believe it may be an issue with the extruded but not sure. All parts come out looking like this to come degree. The imagine should allow for zooming enough to see mushroom headed severed ends in the affected areas.
Ideas?
Opublikowany : 21/04/2022 1:12 pm
Bob
 Bob
(@bob-2)
RE: Strange separations of the filament on the print aka holes
Other than those gaps the print looks fantastic.  I don't know if this is a fix, but you can check your calibration and see what's going on.  There is a good tutorial here:
https://all3dp.com/2/extruder-calibration-6-easy-steps-2/
That'll walk you through it.
Cheers
-Bob
Opublikowany : 21/04/2022 1:32 pm
Chris Laudermilk
(@chris-laudermilk)
I've seen it mentioned to check your retractions for that kind of surface flaw. No expertise in it myself, but it's something to look at.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 21/04/2022 2:08 pm
radianrad
(@radianrad)
For sure! Looks great otherwise, but the holes are very bad in places.
I'll give this a shot. Thanks!
Opublikowany : 21/04/2022 3:38 pm
radianrad
(@radianrad)
I'm at the default retraction of 3.2mm. Would you try more or less?
Opublikowany : 21/04/2022 3:39 pm
sandysasmita
(@sandysasmita)
Change the retraction from default 3.2mm to 2.0mm... it should works for prusa mini.
Opublikowany : 21/04/2022 10:09 pm
radianrad
(@radianrad)
This did it! The results are astounding. Thank you much.
Posted by: @sandysasmita
Opublikowany : 23/04/2022 9:18 pm
2 ludzie polubili
languer
(@languer)
Thank you @radianrad for posting your results.
And thanks @sandysasmita for providing the solution. I had followed your postings in Reddit for this as well: Weird holes peppered throughout print
Opublikowany : 24/04/2022 11:45 pm
