PRUSA MINI Extruder
Daniel
(@daniel-30)
PRUSA MINI Extruder
Dear Friends,
I just baught my first 3D printer, a PRUSA Mini.   I assembled all the parts, did all the self tests and wanted to load the PLA filament in the Extruder.  The filament could never enter the extruder although I tryed to push it in.  I did 10 times the load and unload program, opened the little flap door on top and saw the gearing working,  but the filament is somehow blocked, not able to enter the Extruder.  I wanted to know if someone had the same issue before I start to take it appart.
Thanks
Daniel
This topic was modified před 2 years by Daniel
Napsal : 10/05/2023 12:50 pm
JMH714
(@jmh714-2)
RE: PRUSA MINI Extruder
Okay, but we need to know what you have on your Mini - do you have filament sensor installed (that is sold separately)?
Did you cut filament 45 degree before insert in?
Napsal : 10/05/2023 5:01 pm
How far in does your filament reach?  'Load' it and mark it at the point where it enters then unload and offer it up against the outside to see where the block is.
Napsal : 10/05/2023 10:52 pm
Daniel
(@daniel-30)
i have the sensor.  the filament enters 3 cm into the extruder then it is blocked from further entering.
Napsal : 11/05/2023 6:19 am
So hold the filament against the outside of the extruder, follow the path and you now know exactly where to look for the issue ...
Napsal : 11/05/2023 10:15 am
Did you cut the filament at a 45 degree angle?
Is the idler screw too tight?
Short of that, all I can think of is some misalignment in the build.
Napsal : 11/05/2023 10:55 am
Daniel
(@daniel-30)
Hello,
yes i did
Napsal : 11/05/2023 11:14 am
JMH714
(@jmh714-2)
If you did those suggestion above, then try to take extruder area apart and re-assemble it (be sure to follow instruction carefully). But don't over tight screws - tighten it a little bit. That I would do if I was in same situation as you are. 🤫
Napsal : 11/05/2023 2:38 pm
Daniel
(@daniel-30)
Thank you
yes that is my next step
thanks
regards
Daniel
Napsal : 11/05/2023 4:54 pm
