Problems with first calibrating Prusa Mini Plus (Kit)
I bought a Prusa Mini Plus as a Kit and mounted it in the past few days. Great manual on Prusa's site. Upgraded the firmware to version 4.4.0. Now when I run the Wizard I get a red cross at the X axis. The Y axis gets a green tick and at the Z axis is not tested ? When applying manual movement of the XYZ axes I see "abnormal" values. X value -2, Y value -3, Z value 0. What am I overlooking here ?
Regards,
Posted : 28/12/2022 12:34 pm
check that both X rods are 0 degrees to each other.
If that is correct then it may be that the GT2 tire is too tight.
In that case, lower the tension on the GT2 belt.
And run the test again.
Posted : 28/12/2022 3:49 pm
