Problems with contour ...
Helo I hawe a problem with printing big stuf as you can se on te photos.
There are some bugs from the design but the thing that i am the moust cosernd is the part with 2 uper rows of windows the shell is broken weak and tereble looking. i will probobly use some paste and sand paper to make it look good. But for future i was cerious what can i do to prewent it from happening. i was using the orange filament from this set https://botland.store/filament-sets/18607-try-different-colors-of-pla-filament-small-set.html and pre configured setings for pla in prusa slicer and on prusa mini. Using suports and without the skirt.
Before the print i did 2 cold pulls becouse i was changing from petg to pla.
I really aprisheate if you could tell me whats the problem
Szymon Grabowski form poland
Also sorry for miss spelling and bad gramar... 😐
RE: Problems with contour ...
It looks a bit like the nozzle is clogging or the extruder isn't pushing filament well.
You could try slowing down the print speed, or increasing nozzle temp.
Definitely underextrusion. Do a cold pull and clear the clog.
