Mesh bed leveling failed.
Seite 1 / 2
Bernd
(@bernd-6)
I have the problem that the Mesh bed leveling failed. I have seen the other thread about the MINDA adjustment but in my case the nozzle doesn't touch the bed. After makeing the 4th test at the bed front the error message occurs. I tried different probe heights already and played with z-Axis offset up to -1mm but always get the same error. Is there anything else to check apart of the probe high?
BTW: I'm new to 3d printing.
Thanks
Bernd
Best Answer by Jakub K.:
I had the same issue yesterday when assembling the printer. I called to the support and they told me the MINDA sensor might be malfunctioning, but that wasn't actually the case.
I found out that the real root cause for me was that the bed was inclined by a few millimeters to Z axis (there wasn't 90 degrees angle, but slightly more) which caused that the nozzle was touching the bed on the right side, but when it moved to the left side there was relatively big space between the nozzle and the bed (so big that the software couldn't compensate and the mesh bed leveling failed).
Once I realized the issue, I was able to fix it by loosening the 3 screws holding the Z axis to the base, then putting a thick piece of paper between the lower part of the box with electronics and the base rail, and then by tightening those screws again. That effectively compensated the deviation and the bed have almost perfect 90 degrees angle with the Z-axis now.
I am glad that I was able to fix it by myself, though I am a little angry that I have now a few scratches in the steel sheet from the noozle from the failed leveling callibration.
I hope it helps,
Jakub
Dieses Thema wurde geändert Vor 5 years von Bernd
Veröffentlicht : 17/12/2019 11:06 pm
Andariel und Jakub K. gefällt das
padigree
(@padigree)
RE: Mesh bed leveling failed.
https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/distance-m-i-n-d-a-probe-to-nozzle-tip/
Also a problem in the other direction. Mentioned some credit cards to manually adjust the Minda. Maybe this helps.
It’s better to give than to receive. Especially advice.
Veröffentlicht : 18/12/2019 4:37 am
Bernd
(@bernd-6)
Thanks, yes I have seen that. I've tried already a few different high setups. All with the same result. Will try it again, mabe with a fresh fatory reset.
Veröffentlicht : 18/12/2019 10:53 pm
Crawlerin
(@crawlerin)
Do you have the steel sheet on bed while leveling? I am asking because there was few people who had MBL failed and they did not put steel sheet on.
Veröffentlicht : 19/12/2019 1:40 am
Different heights of the two Z stepper motors, x-axis inclined at height to the bed? Move the extruder to the left, afterwards to the right side and compare the nozzlehigh. The same procedure in y-direction.
Veröffentlicht : 19/12/2019 2:02 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Posted by: @karl-herbert
Mini has only one Z stepper 😉
Peter
Veröffentlicht : 19/12/2019 8:35 am
@pjr
Sorry, wrong section!
Veröffentlicht : 19/12/2019 1:04 pm
Jakub K.
(@jakub-k-2)
I hope it helps,
Jakub
Diese r Beitrag wurde geändert Vor 5 years von Jakub K.
Veröffentlicht : 19/12/2019 5:09 pm
karl-herbert gefällt das
@jakub-kohoutek
Thanks for the information. Glad you were able to solve the problem. Another variant of inclination.. 😆
Veröffentlicht : 19/12/2019 7:24 pm
Bernd
(@bernd-6)
Thanks Jakup, that sounds promissing. I will check that during the weekend.
Bernd
Veröffentlicht : 19/12/2019 9:27 pm
Nick Danger
(@nick-danger)
I’m having a similar issue. However I printed 3 items before the issue showed up.
when it does the check for mesh leveling it’s fine on the right side and way up the air on the left.
 I’ll give the Z axis a loosen and re-tighten and check it’s alightment.
Veröffentlicht : 21/12/2019 4:16 am
Bernd
(@bernd-6)
Hey Jakup, I have exactly the same problem ass you described and your tip with adding a think paper at the bottom between the two peaces solved it for me too.
Many thanks, you saved Christmas (slightly exaggerated 😀 ).
Bernd
Veröffentlicht : 21/12/2019 11:40 am
Flyingramses
(@flyingramses)
As a newbie awaiting my first i3 delivery, it is slightly concerning that I may need to use sheets of paper and credit cards to get the bed levelled correctly.  I take it this is rare and most issues like this are ironed out by Prusa.
Veröffentlicht : 24/12/2019 6:22 am
Posted by: @simon-roberts13
This is the group for the newly-released Mini. The Mk3 has been around awhile (assuming you've got an Original Prusa i3 Mk3) and does not generally have these issues. These sorts of things tend to get ironed out pretty quickly on a new release. The Mk3 had its share of quirks at the start, but it's a very mature and reliable platform now.
Veröffentlicht : 24/12/2019 7:16 am
Flyingramses
(@flyingramses)
Hi bobstro.  Ah thanks, I forgot I was on the Mini group, I ordered the Mini but felt the wait was too long so took the plunge for the i3 which arrives in January 🙂 !  I will browse the i3 forum, very excited!
Veröffentlicht : 24/12/2019 9:21 am
Nick Danger
(@nick-danger)
Got my new MINDA sensor and all is well again with the mini.
Happy Printing and New Year!
Veröffentlicht : 27/12/2019 8:43 pm
aleksandard
(@aleksandard)
@printguy
hi 🙂 do you have a picture for me? maybe i have similier problem 🙁 thx
Veröffentlicht : 16/04/2020 9:14 pm
Nick Danger
(@nick-danger)
@aleksandar-dimitrov Here is a video of what it can looks like when the sensor is failing.
In the case for this video it is only failing on the left side (happened because the sensor wires were getting pulled as it moved far to the left).
Veröffentlicht : 16/04/2020 9:18 pm
Onlinedriver
(@onlinedriver)
Hello! I had the same problem. I unscrewed all three screws and forcing very little angle (pushing the Z-axis motor), I tightened the screws back. Thus I achieved the angle of 90 degrees. I gave reset and recalibration. It came out very well.
Veröffentlicht : 17/04/2020 3:02 pm
Suliman
(@suliman)
Pictures please which threads I should loosing and tighten
Veröffentlicht : 09/11/2020 10:03 pm
Seite 1 / 2
