Live Z Adjustment test is perfect but prints are garbage
WillDeed
(@willdeed)
I've had the MINI+ for a while now, so this isn't my first print, but my prints are turning out garbage now and I don't know how to fix it. Things I've tried:
Update the firmware to 6.4.0 11974
Update the slicer to 2.9.4
Replace the nozzle
REALLY clean the build plate (hot water + soap + scrubbing + paper towel)
Live adjust Z (dialed in perfectly)
Bed level test (Specifically the MINI 3mf file)
Left: 0
Right: 100
Front: 0
Rear: 0
Left: 10
Right: 80
Front: 50
Rear: 60
Live Z Adjust is dialed in perfectly at 1.775
Any suggestions?
Opublikowany : 02/02/2026 11:15 pm
_KaszpiR_
(@_kaszpir_)
Seems like PLA. Could be clogged nozzle or problems with extrusion. Double check the PTFE tubes if they are ok.
You can just rise the nozzle and see if it extrudes  evenly.
Opublikowany : 04/02/2026 6:01 pm
