Leveling probe has inconsistent pattern while bed leveling
Deniz
(@deniz)
I have the Problem that everytime i start the print the bed leveling is a bit weird.
Nomaly the printer just goes from one place to another goes up and down 2 times I think (just like it normaly does) but at some places it repeats this or drives further up and starts again at that point. I already tried puting the probe up and down and I upgraded the firmware to newest version.
The print after is just fine and the quality is great.
I know that this behavior is not normal because we have a prusa at work the only difference is that the on at work was prebuilt and i had the kit
That link is a video of my printer
https://youtube.com/shorts/bS-HwbQBkQI?feature=share
Opublikowany : 06/01/2023 1:31 pm
RE: Leveling probe has inconsistent pattern while bed leveling
Posted by: @kampffisch12
Mine does something similar,
but like you, I get good prints,
In the past I have re run the calibration wizard, which has temporarily corrected the issue.
Have you tried increasing the number of tests at each point?  to see if that resolves the issue?  mine is currently set to 5
do you have magnet compensation turned on?
this option reduces the 49 test points down to 42, to take account of where the magnets impact upon the pinda tests.
Opublikowany : 06/01/2023 1:44 pm
Deniz
(@deniz)
Alright Thanks for the quick answer.
Can I change these settings directly on the printer ?
Opublikowany : 06/01/2023 1:51 pm
Yes. LCD menu. Settings... Mesh bed levelling
I believe
Opublikowany : 06/01/2023 4:25 pm
Deniz
(@deniz)
Okay I will try that tomorrow
Opublikowany : 06/01/2023 4:27 pm
Deniz
(@deniz)
I just now had time to look at the setting. Yes it was all ready turned on. And I had the test point number at 3 now its 5.
I will print something and see if it still does the same thing
This post was modified 3 years temu by Deniz
Opublikowany : 10/01/2023 3:36 pm
Deniz
(@deniz)
The printer still did it but only 2 times. I think that is good enough for me 😆
Opublikowany : 10/01/2023 3:46 pm
