Jagged lines on a .8mm first layer test?
I just swapped out my .4mm for a .8 and ran the first layer test. A lot of my lines were decent, but would get jagged. It was almost like the machine was feeding .4mm worth of filament to a .8mm nozzle and it get stringy.
Is that right, or did I do something wrong on install?
Posted : 17/03/2021 8:22 pm
RE: Jagged lines on a .8mm first layer test?
Check your slicersettings and make sure the profile you used are set for 0.8 and 1.75mm filament.
I have made that mistake when swapping out for a 0.6 nozzle.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Posted : 18/03/2021 12:14 am
