INCREDIBLY frustrated
Page 1 / 2
Kyle Kerby
(@kyle-kerby)
Hey all,
I'm frustrated as hell here. I have a Mini+ with IS, and I can't get consistent prints. I am certain it's related to the filament, but that's where my frustration lies. I have Sunlu, Hatchbox, and Overture filaments, both in PLA and PETG, but there are no profiles for them in PrusaSlicer. I REALLY want to stick with the native slicer as that makes the most sense to me, but I can't keep wasting time and materials trying to make this work. I know everyone is going to say "buy filament you have a profile for" but I can't justify just dumping a few hundred dollars in filament just because the Slicer doesn't have a profile for it.
Is there a way to make this thing work before I just give up all together? I'm irritated because I've had it work well after a ton of time and materials tweaking it, but then when I open a new file I have to start all over and I just don't have the time. I don't know what to do here and there are 347 different test print files on Printables and I have no idea what ones are work using and what ones are poorly done and will just be a waste of time and materials.
I need to be able to select the filament, the file, and hit "go" and walk away and go to work and not have to worry about coming home later to a spaghetti mess or horrible prints. Can someone PLEASE help me?!
Posted : 22/07/2024 2:04 am
Saphir
(@saphir)
I always start with the Prusament profiles, make test prints and adjust them to my needs. After every test I SAVE the Profile and name it after the filament I used. You can access all profiles you have saved later on! You can access unsaved profiles if you are able to open a .3mf-file where you used this profile because it is automatically saved within the .3mf-file and you can save them into printables using the computer disk symbol next to the name in the settings.
This post was modified 2 years ago 2 times by Saphir
Printing PLA and PETG at the same time? See the Guide for MultiMaterialSupports ----- Ejecting Buffer cassettes is not satisfying? May the Fork be with you!
Posted : 22/07/2024 12:01 pm
Kyle Kerby
(@kyle-kerby)
RE: INCREDIBLY frustrated
Thank you for the info, I will try that. However, can someone point me in the direction of what a good test print file would be to be able to do the tests with that will give me a clear answer if I got the settings right or not before I save a bunch and get lost on what worked and what didn't? Also is there anything you can refer me to where I can be able to look at the bad prints and be able to analyze them to tell WHAT went wrong so I can make appropriate changes? (ie, too hot, too cold, whatever other parameters I can change) Thanks again for the help and have a great day!
Posted : 07/08/2024 11:18 pm
Kyle Kerby
(@kyle-kerby)
Posted by: @kyle-kerby
To be clearer about my question I guess, I have a laser printer that has a built in program that allows me to put in baseline parameters and then have it run a test cut to see what's going to work, which is essentially a grid with increasing speed on 1 axis, and increasing power on the other so that you can see what's going to be best (see photo). Is there anything like that for 3d printing? Because I think that would help tremendously.
Posted : 07/08/2024 11:25 pm
Saphir
(@saphir)
I always start with the benchy boat. You can find it in the prusaslicer gallery when adding a new object or referred in the collections of prusa research on printables.
it can tell you much about your settings. Benchy homepage
This is the only test I do but I know my printer is in a good condition and well tuned.
There are tons of other tests out there. Some for the printer and some for the filament. To name only a few: xyz calibration, overhang test, bridging test, retraction test, ringing test, esteps calibration, temptower,..
Almost every screw of your printer has its own test. Do you need all of them? Look at your print and you will know.
Perhaps you are looking for a test called "temptower" to dial in your optimal printing temp. This could be the equivalent of the picture you posted.
Beware that too low temps will make the layers not bind together. So make a breaking test with every temp tower!
Don't mess around with too many tests. You bought a prusa, you are a printer now 😉
Just print and look at your prints. Are you satisfied? No? Search for the problem you see and dial this one in. There are tons of tutorials how to dial in a printer and troubleshoot. Especially on the homepage of your printers manufacturer.
This post was modified 2 years ago by Saphir
Posted : 08/08/2024 5:16 am
fabnavigator
(@fabnavigator)
I'm sorry you got to the point of being incredibly frustrated. I don't know what your financial situation is, and I don't know how you value your time, but my suggestion is buy some Prusament from Prusa and see if you are satisfied with the print quality using their default slicer settings. I hardly ever need to deviate from the default settings for Prusament.
To save the cost of buying filament from Prusa, I recently bought three spools of Printed Solid Jessie PETG filament. They were less than 1/2 the price of buying, and shipping from Prusa. Printed Solid is owned by Prusa, and there are profiles in PrusaSlicer. It seemed like a safe bet.
Turns out that they didn't print as well as Prusament. The first thing I noticed was that they melted at a lower temperature so I had oozing to deal with during bed leveling. The print quality is acceptable for iterative test models, but not for many final prints.
Instead of spending who knows how much time trying to get better quality out of the Jessie filament I ended up ordering more Prusament.
Posted : 08/08/2024 11:49 am
Kyle Kerby
(@kyle-kerby)
Thanks for the reply, and you're probably right. I don't mind spending the extra $10 or so per spool, but the international shipping is a gut punch. I almost pulled the trigger last night on some Prusament but 2 spools shipped was almost $80. If you're telling me that it will for sure print awesomely (that's probably not a word) with the premade filament profile, I'll probably do it. I just waste so much time and filament on a daily basis trying to make this thing work that if it happens with $40/spool filament I'm just going to snap haha! I just wish they had US distribution so that I could verify it's going to work before spending that cash. Ahh the joys of learning new stuff...
Posted : 08/08/2024 1:38 pm
fabnavigator
(@fabnavigator)
I feel the same way about the shipping. I bought four spools and some nozzles to blunt the blow.
I have no experience with he Mini+. I had an MK3S, and now I have an MK4. Will the Prusament print perfectly? Of course I can't say. Not to have you waste any more of your time, but did you at least try to print w/o IS?
Posted : 08/08/2024 3:49 pm
Kyle Kerby
(@kyle-kerby)
I have not. Should I? It's SO slow without IS and I didn't think it would matter. As I understand it, the issue with IS is that the hotend can't keep up sometimes yeah? I have upgraded my hotend and extruder with the Slice Engineering upgrade and have never seen it struggle to maintain temp even with IS on. Is there another reason not to use IS that I'm not aware of?
Posted : 08/08/2024 4:04 pm
fabnavigator
(@fabnavigator)
At times I've had to print slower to get the quality I wanted. Turning off IS is just another way of slowing the printer down. It's not a final solution, but if you are waiting for some new filament it might be interesting to see the results.
Posted : 08/08/2024 4:31 pm
Kyle Kerby
(@kyle-kerby)
Interesting. Okay I'll try that and see what it does. Thanks for the tip!
Posted : 08/08/2024 7:13 pm
Kyle Kerby
(@kyle-kerby)
Okay so I made some changes, disabled IS, and found a profile for my Hatchbox PLA and the print came out GREAT! Then I tried my Overture PETG for the same print, and had a problem but was MUCH closer than I've been before, so I'm getting (cautiously) optimistic!
So I ran the "generic PETG" profile for it and had poor print quality on the bow. So I tried to figure it out and in so doing, I made fan run at max after 5 layers, fan on always, and changed the infill to rectilinear, dropped bed temp by 5 degrees, and none of them changed what was happening. The rest of the print came out great so I don't think print speed or temp is a factor, but I'm lost where to go from here. Any thoughts? See attached photos for details.
Posted : 10/08/2024 12:16 am
Kyle Kerby
(@kyle-kerby)
Posted : 10/08/2024 12:18 am
fabnavigator
(@fabnavigator)
Try reducing the hotend temperature by 10 degrees.
Posted : 10/08/2024 3:14 am
Kyle Kerby
(@kyle-kerby)
Okay I tried that and had the same issue with separation on the sides as well. Dropped another 10 degrees and it got worse. Added 10 degrees from baseline and it was horrible. So I THINK the temp I was at is correct being that everything looked good except that bow area. So what other parameters could I work with to dial that issue in?
Posted : 10/08/2024 6:45 pm
Woodburner
(@woodburner)
It will not hurt to dry your filament also, i had issues with new spools of PETG until i started drying. mini+ seems to devour any filament i have used so far. but it must be dry.
Master of Wood Disaster
Charter member of the woodturners funnel club
Posted : 10/08/2024 6:54 pm
Walter Layher
(@walter-layher)
How was the benchy oriented on the print bed? With the bow pointing to the front or to the back? In the latter case you could try to rotate the model to make the bow point the other way. Could be the cooling of the fan for overhangs is insufficient in this orientation. I arrived at better results for overhangs when I changed to a bidirectional shroud for the parts fan on my MK4. I have not researched for the Mini, but for the MK4 and the MK3xx there are multiple mods on Printables, so I expect there could be similar mods for the Mini.
Posted : 10/08/2024 7:25 pm
Kyle Kerby
(@kyle-kerby)
Okay I tried rotating it, and then I got a whole new error (FUN!). It stopped a few layers in, gave this error message, and kept the bed heater on. I reset the machine and tried again and it worked just fine. Then on the next print, it did the same thing. I ran all the self tests and they all passed. What does this mean?
Posted : 13/08/2024 12:03 am
Walter Layher
(@walter-layher)
Perhaps the bearing of the fan is blocked or the fan has just reached EOL. You could try replacing the fan and see if the problem persists. Having a spare fan around is not a bad idea, perhaps except if you have just ordered some spare fans for your MK4 and the next week Prusa introduces a totally new model making the fans you just received obsolete. 🙂
But fans are consumables and not the most expensive spare parts to keep as spares.
Posted : 13/08/2024 6:26 am
Kyle Kerby
(@kyle-kerby)
Okay new issue here. I FINALLY got the Benchy to print properly (almost FLAWLESSLY) but then forgot to plug in my computer and the battery died! When I fired it back up, the app was obviously closed so I have no idea what the last changes I made were that made it work right! I have a bunch of Benchy's on my flash drive but to save myself from having to print them all to figure out which one worked right, is there a way to load the GCODE file from my flashdrive into PrusaSlicer and bring the settings back up to save them? Whenever I try it just opens the GCODE Viewer which just shows me the model and no filament profiles. PLEASE tell me I don't have to start back from scratch! 🤞🤞🤞🤞
Posted : 29/08/2024 1:53 am
Page 1 / 2
