Heavy Stringing
kairikitty
(@kairikitty)
Heavy Stringing
I just received my Prusa Mini and I love it, but I have a bit a of a stringing problem.  The test prints on the Flash Drive had some decent stringing on them, so for my first print I set up Prusa Slicer and sliced a stringing test at the default settings.
I'm not sure if this is a assembly problem where I have put something together wrong or if I just need to fix my settings or what.
Napsal : 16/05/2020 4:50 pm
RE: Heavy Stringing
Have you tried a temperature tower?
it may help you find settings that work with your printer and filament combination
there are sample G codes in the Prusa Printers web site.
Make sure that the G code has actually been modified to change temperature at the required levels
Napsal : 17/05/2020 3:49 pm
