Firmware Bug ( first time Wizard not working) Prusa Mini Self Test Problem
fantasyterrain.de
(@fantasyterrain-de)
Hi @ all
I have q big problem with my new mini :
Best Answer by padigree:
Pinned comment below the video:
"solution found sheet must be on it during the self test !"
But btw, the y axis sounds horrible.. Sounds like the sensorless homing would also not work properly.
Publié : 17/12/2019 10:52 pm
pingu
(@pingu)
RE: Firmware Bug ( first time Wizard not working) Prusa Mini Self Test Problem
I habe the same problem
Publié : 18/12/2019 5:32 am
Oxygen
(@oxygen)
What was the issue, since the topic of the video has (solved) in it...
Stock MK4S
Publié : 18/12/2019 7:29 am
padigree
(@padigree)
It’s better to give than to receive. Especially advice.
Publié : 18/12/2019 7:38 am
Oxygen
(@oxygen)
Ah sorry, I looked at the video inline and did not see the comments -- thank you for the update
Stock MK4S
Publié : 18/12/2019 7:46 am
fantasyterrain.de
Wizard bug on self test use the Sheet and the self check will be passed
Publié : 18/12/2019 11:16 am
Crawlerin
(@crawlerin)
Maybe it would not hurt if it reminds about it on display, if it does not do tgat already.
Publié : 18/12/2019 1:23 pm
towlerg
(@towlerg)
Kindda harsh to call this a bug.
Publié : 18/12/2019 2:14 pm
Crawlerin
(@crawlerin)
@towlerg
No, it's not a bug, but can be frustrating nonetheless. If reminder of putting steel sheet to bed makes even just a few customers less frustrated, it may be worth putting it on screen or in manual.
Publié : 18/12/2019 2:28 pm
towlerg
(@towlerg)
@crawlerin
Point taken. It should be in the manual.
Publié : 18/12/2019 3:35 pm
towlerg
(@towlerg)
I had a look at the assemble instructions and Step 34 seems pretty clear. Also Step 35 shows the plate in place and notes "Place the PEI MINI sheet on the heatbed. Double-check it is oriented correctly."
Ce message a été modifié il y a 6 years par towlerg
Publié : 18/12/2019 3:55 pm
Texy
 Texy
(@texy)
That's fine when you are building and doing the very first calibration, but it needs to be clear, on-screen, from then onwards.
Publié : 18/12/2019 4:07 pm
