Firmware Bug ( first time Wizard not working) Prusa Mini Self Test Problem
Hi @ all
I have q big problem with my new mini :
Best Answer by padigree:
Pinned comment below the video:
"solution found sheet must be on it during the self test !"
But btw, the y axis sounds horrible.. Sounds like the sensorless homing would also not work properly.
RE: Firmware Bug ( first time Wizard not working) Prusa Mini Self Test Problem
I habe the same problem
What was the issue, since the topic of the video has (solved) in it...
Stock MK4S with FW 6.2.6
Itâs better to give than to receive. Especially advice.
Ah sorry, I looked at the video inline and did not see the comments -- thank you for the update
Wizard bug on self test use the Sheet and the self check will be passed
Maybe it would not hurt if it reminds about it on display, if it does not do tgat already.
Kindda harsh to call this a bug.
@towlerg
No, it's not a bug, but can be frustrating nonetheless. If reminder of putting steel sheet to bed makes even just a few customers less frustrated, it may be worth putting it on screen or in manual.
@crawlerin
Point taken. It should be in the manual.
I had a look at the assemble instructions and Step 34 seems pretty clear. Also Step 35 shows the plate in place and notes "Place the PEI MINI sheet on the heatbed. Double-check it is oriented correctly."
That's fine when you are building and doing the very first calibration, but it needs to be clear, on-screen, from then onwards.
