Extruder Failure + Blockage
Strona 2 / 2
Yaniv Shachar
(@yaniv-shachar)
RE: Extruder Failure + Blockage
Hello,
FWIW I managed to address a somewhat similar issue by turning the nozzle temperature all the way to 260c, then gently pushed the filament to allow it to manually purge. HTH.
Opublikowany : 06/06/2024 8:10 pm
Carolina Customs
(@carolina-customs)
I had somewhat a similar problem after the first few prints. turned out the gear on the stepper motor shaft came loose. still went ahead and did a Bondtech IFS extruder and the slice engineering copperhead heatend kit upgrade ... now just having to tune the values ... there are also other extruder and Hotend upgrades out there ...
Opublikowany : 13/08/2025 1:20 am
Strona 2 / 2
