Cleaning between calibration
Rost
 Rost
(@rost-2)
Should I let the hotbed cool down before removing the calibration pattern between calibrations? I've been having to calibrate it quite a lot. I'm been lowering it at small increments and now I've found that -1780 seems to give ok prints. But, after a calibration, the print head do not retract much and the y-axis do not push forward to make it easy to inspect the pattern, or to clean it. So just wanted to check if I was doing anything wrong?
/First 3D-printer, first post.
Posted : 04/12/2020 11:32 am
