Cannot set Z low enough
Tr1kon
(@tr1kon)
Just got a prusa mini and in calibration i cannot set the Z level low enough to print with my textured print sheet as it caps out at -2 so currently I can only print on the flat steel sheet. Is there any simple fix to this?
Posted : 23/06/2021 9:25 am
Steve Smith
(@steve-smith)
RE: Cannot set Z low enough
Raise the Filament sensor..
My Mini has: A SuperPINDA + Bondtech Heatbreak + Bondtech Extruder installed
Posted : 23/06/2021 9:58 am
BogdanH
(@bogdanh)
What Steve Smith meant is, slightly raise PINDA sensor 🙂
Don't pull it up too much, because you can damage coating on print sheet (about 0.5-1mm should be enough).
[Mini+] [MK3S+BEAR]
Posted : 23/06/2021 10:14 am
jcjames_13009
(@jcjames_13009)
Hi
Procedure  well explained in Prusa knowledge base https://help.prusa3d.com/en/guide/7-preflight-check_204705#204713
I did it on my MINI+ and 1st layer calibrations for both scooter PEI and textured plates went perfect
JC
Prusa MINI+ at home / Prusa MK3S+ in the Fab Lab / You can have a look at my designs here printables.com
Posted : 23/06/2021 7:46 pm
jcjames_13009
(@jcjames_13009)
Sorry please read smooth PEI plate not scooter 😖
Posted : 23/06/2021 8:03 pm
