					                		Buenas tardes. Me está dando problemas la impresora. Me indica problemas en el cableado del termistol, lo he cambiado completamente y me sigue dando el mismo problema. Escaneo el código QR y me indica error desconocido. Me puede ayudar alguien? Mu... - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/buenas-tardes-me-esta-dando-problemas-la-impresora-me-indica-problemas-en-el-cableado-del-termistol-lo-he-cambiado-completamente-y-me-sigue-dando-el-mismo-problema-escaneo-el-codigo-qr-y-no-me-ind/</link>
                <lastBuildDate>Wed, 10 Jun 2026 05:59:12 +0000</lastBuildDate>
                        <title>RE: Buenas tardes. Me está dando problemas la impresora. Me indica problemas en el cableado del termistol, lo he cambiado completamente y me sigue dando el mismo problema. Escaneo el código QR y me indica error desconocido. Me puede ayudar alguien? M...</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/buenas-tardes-me-esta-dando-problemas-la-impresora-me-indica-problemas-en-el-cableado-del-termistol-lo-he-cambiado-completamente-y-me-sigue-dando-el-mismo-problema-escaneo-el-codigo-qr-y-no-me-ind/#post-779470</link>
                        <pubDate>Sat, 24 Jan 2026 14:07:41 +0000</pubDate>
                        <description><![CDATA[Error code 12208 is a &quot;Mintemp error&quot; -- the hotend is measured to be below 15°C. One possible reason is that the printer simply sits in a room which is too cold. It is recommended to move i...]]></description>
                        <content:encoded><![CDATA[<p>Error code 12208 is a "Mintemp error" -- the hotend is measured to be below 15°C. One possible reason is that the printer simply sits in a room which is too cold. It is recommended to move it to a warmer room, because the print quality may suffer when the environment is too cold. As a workaround, you can use a hairdryer to warm up the extruder a bit before you start the printer (and start pre-heating) -- it will not take much to get above 15°C..</p><p>If a cold room is not the cause, the thermistor or its connection to the main board are probably bad. Which specific parts have you replaced already?</p><p>https://help.prusa3d.com/es/article/error-mintemp-en-el-fusor-12208-mini_154845</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Jürgen</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/buenas-tardes-me-esta-dando-problemas-la-impresora-me-indica-problemas-en-el-cableado-del-termistol-lo-he-cambiado-completamente-y-me-sigue-dando-el-mismo-problema-escaneo-el-codigo-qr-y-no-me-ind/#post-779470</guid>
                        <title>Buenas tardes. Me está dando problemas la impresora. Me indica problemas en el cableado del termistol, lo he cambiado completamente y me sigue dando el mismo problema. Escaneo el código QR y me indica error desconocido. Me puede ayudar alguien? Mu...</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/buenas-tardes-me-esta-dando-problemas-la-impresora-me-indica-problemas-en-el-cableado-del-termistol-lo-he-cambiado-completamente-y-me-sigue-dando-el-mismo-problema-escaneo-el-codigo-qr-y-no-me-ind/#post-779356</link>
                        <pubDate>Fri, 23 Jan 2026 12:21:05 +0000</pubDate>
                        <content:encoded><![CDATA[<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/b3ab7dfa-img_20260123_124514-scaled.jpg"><img class="alignnone size-medium wp-image-183596" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/b3ab7dfa-img_20260123_124514-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>JOSE MARIA REYES PRIETO</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/buenas-tardes-me-esta-dando-problemas-la-impresora-me-indica-problemas-en-el-cableado-del-termistol-lo-he-cambiado-completamente-y-me-sigue-dando-el-mismo-problema-escaneo-el-codigo-qr-y-no-me-ind/#post-779356</guid>
