Buenas tardes. Me está dando problemas la impresora. Me indica problemas en el cableado del termistol, lo he cambiado completamente y me sigue dando el mismo problema. Escaneo el código QR y me indica error desconocido. Me puede ayudar alguien? Mu...
JOSE MARIA REYES PRIETO
(@jose-maria-reyes-prieto)
Miembro
Respondido : 23/01/2026 12:21 pm
RE: Buenas tardes. Me está dando problemas la impresora. Me indica problemas en el cableado del termistol, lo he cambiado completamente y me sigue dando el mismo problema. Escaneo el código QR y me indica error desconocido. Me puede ayudar alguien? M...
Error code 12208 is a "Mintemp error" -- the hotend is measured to be below 15°C. One possible reason is that the printer simply sits in a room which is too cold. It is recommended to move it to a warmer room, because the print quality may suffer when the environment is too cold. As a workaround, you can use a hairdryer to warm up the extruder a bit before you start the printer (and start pre-heating) -- it will not take much to get above 15°C..
If a cold room is not the cause, the thermistor or its connection to the main board are probably bad. Which specific parts have you replaced already?
https://help.prusa3d.com/es/article/error-mintemp-en-el-fusor-12208-mini_154845
Respondido : 24/01/2026 2:07 pm
