Brand new MINI+ Z height wackyness
BartyDeCanter
(@bartydecanter)
I have a brand new MINI+and can not get the z-height adjusted correctly.  While doing the calibration test I find that I can get the right side of the bed to stick (at a Z calib of -0.975) but the left side is about 5mm in the air!!!  How do I fix this?
Napsal : 12/03/2021 1:02 am
BartyDeCanter
(@bartydecanter)
RE: Brand new MINI+ Z height wackyness
I’ve taken a closer look and it appears the the Z axis is not quite perpendicular to the xy plane. Is there an assembly issue than can cause this? Or is this a known issue?
Napsal : 12/03/2021 3:32 am
draeh
(@draeh)
Kinda sounds like the X/Z arm isn't mounted perpendicular to the bed.
Napsal : 12/03/2021 5:41 am
hagensieker
(@hagensieker)
On the end of the X axis are the two idler screws.  Get 2 of something, anything, as long as they are the same length and will sit under the rods.  Put one on the right, and one on the left. Adjust idlers until level.  I used two metal rods the same length.  You can literally use anything.
This post was modified před 4 years 2 times by hagensieker
Napsal : 12/03/2021 11:30 am
1 lidem se líbí
BartyDeCanter
(@bartydecanter)
@hagensieker
Thanks!  I found the instructions for adjusting that at https://help.prusa3d.com/en/article/xz-axis-skew-correction-mini_158518
However, even after adjusting those screws as far as they would go, the left side is still 2-3 mm in the air when the right is at zero.
Napsal : 12/03/2021 1:52 pm
BartyDeCanter
(@bartydecanter)
After chatting with the extremely helpful prusa support, this is a know issue with a simple fix for some people.  You slightly loosen the two screws each on the front and back of the right base extrusion, rotate the whole z-axis until it is level and then tighten them down.  They will be adding that to the manual soon.
Napsal : 12/03/2021 2:50 pm
1 lidem se líbí
