bed not level - mesh bed leveling does not compenstate
Page 1 / 2
Mike
 Mike
(@mike-38)
I can't seem to get a good Z offset value - it looks like there is just too much difference from the left side to the right side of the bed. I have cleaned the steel sheet to make sure its sitting correctly. I thought the mesh bed leveling routine was supposed to compensate for this sort of situation. Here is my print that takes up about 2/3rds of the bed, you can see the left side is way too high, leaving gaps between lines, and the right side is way to low, causing very high adhesion to the bed which makes removing the prints very hard and in my case on the reverse side of the bed, already damaged the PEI layer.
I was really hoping this would Just Work out of the box, and super frustrating as I am dealing with almost the exact same issue with my MK3S machine (support is sending me a new PINDA and bed, as my magnets started falling out).
Any advice on how to get the MINI to print level would be greatly appreciated!
(Oh, and upgraded to 4.0.1 just before trying the print pictured below, so that didn't solve it!)
Left side
Right side:
Posted : 22/12/2019 10:11 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
RE: bed not level - mesh bed leveling does not compenstate
Just a couple of things you could check:
The u-bolts holding the bearings.  Make sure that the U-bolts have not been over tightened and that there is a small gap between the top of the U-bolts and the bottom of the bed.  Try sliding a sheet of paper in between the U-bolt and the bed.
Also remove the build plate and make sure that all 9 Torx screws are at least finger-tight.  One or two may have become loose.
Peter
Posted : 23/12/2019 9:38 am
weak
 weak
(@weak)
It would really help if PR would provide tightening torque values (Nm) for all screws.
This post was modified 4 years ago by
Posted : 03/01/2020 11:47 am
ekkilein
(@ekkilein)
To be honest...
I have (more or less), the same problem.
I used bed visualizer (octoprint) to look, how level the bed is. Answer: Horrible. I tried this and that. Nothing helps. Wanted to to the nylon hack, but found out, that the mini is different and it cannot be done in the way like for the MK3(s).
After using nyloc washer under some bad screws its now a bit better (but not flat).
I now expected that Mesh Leveling is compensating and i will have a decent enough print. But after printing a test (with 6 sheets, 1 layer high - https://www.thingiverse.com/thing:3199976) i can see, that some spots (right/left side) of my print are too far away from the nozzle and the other parts a bit to near the nozzle.
Can it be, that the Mesh Leveling in Marlin is not working right? see in addition: https://github.com/MarlinFirmware/Marlin/issues/16397
Here is my mesh:
Recv: Bilinear Leveling Grid:
Recv: 0 1 2 3
Recv: 0 -0.207 -0.078 +0.014 -0.075
Recv: 1 -0.141 -0.066 -0.045 -0.010
Recv: 2 -0.094 -0.174 -0.144 -0.078
Recv: 3 +0.047 -0.179 -0.171 -0.122
Posted : 03/01/2020 1:10 pm
Texy
 Texy
(@texy)
Posted by: @weak
It would really help if the OP at least responded to advice offered, in order to help others.
Posted : 03/01/2020 1:21 pm
ekkilein
(@ekkilein)
Posted by: @joerg-e
To be honest...
Here is my mesh:
Recv: 0 1 2 3
As an addition. My u-bolts are right (checked), my Screws are not overtighten (checked). My Minda seems to work fine. Firmware 4.0.1
This post was modified 6 years ago by ekkilein
Posted : 03/01/2020 1:50 pm
Benji
(@benji)
Perhaps my post here will help: https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/avoiding-early-prusa-mini-issues-common-issues/#post-182742
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Posted : 03/01/2020 2:47 pm
ekkilein
(@ekkilein)
Posted by: @asdf-tgz
Thanks for the hint. I have had done something similar with little paper cards. My problem is, that the right side of the bed is too low. If i am printing only the first layer, i can look trough on some parts on the right.
I now tried a variation of the nylock leveling like for the MK3. Its better now. But not really good. My feeling is, that the Auto Bed Leveling isn't working. Otherwise i wouldn't have parts of the bed where the bed is to low (or the nozzle too high). The ABL must compensate for that if the difference isn't too big. Am i wrong?
My Z is leveled as good as possible. But i can see, that the line on the right isn't flat enough, while on the left everything is fine. Its not much, but detectable.
Can someone please try to check  that with e.g.: https://www.thingiverse.com/thing:3199976
(9o% or 95% percent in prusaslicer).
Posted : 03/01/2020 9:04 pm
ekkilein
(@ekkilein)
My leveling „nightmare“…
My problem is, that some parts of the right side of the bed seems to be too low - the first layer is not ok there (can look trough). In addition, i have the feeling, that ABL is not working because otherwise i shouldn’t have problem because of compensation the ABL is doing with Bilinear(yes, i have a mesh).
I am using firmware 4.01
I checked:
1. all screws (bed and others)
2. my u-bolts are ok
3. the cable to minda seems to be ok
4. live Z is set (-.910)
I wasn’t able to print using the whole bed without having problems as described
I even tried to do a variation of the „nyloc leveling“. I do have better values (see down), but the same problem when i print.
In addition it seems, that i have different values every G29 i initiate
This „G28, G29“ commands are done with cold bed and only one after the other without touching the printer in between.
1st try:
Recv:       0      1      2      3
Recv:  0 -0.063 -0.014 +0.012 -0.032
Recv:  1 -0.017 -0.002 -0.049 -0.071
Recv:  2 -0.079 -0.061 -0.074 -0.110
Recv:  3 -0.121 +0.012 +0.023 -0.115
2nd try:
Recv:       0      1      2      3
Recv:  0 -0.055 +0.032 +0.026 +0.009
Recv:  1 +0.003 +0.016 +0.009 -0.051
Recv:  2 -0.055 -0.032 -0.026 -0.091
Recv:  3 -0.097 +0.068 +0.049 -0.069
3rd try:
Recv:       0      1      2      3
Recv:  0 -0.057 +0.017 +0.021 -0.015
Recv:  1 -0.010 +0.004 -0.020 -0.066
Recv:  2 -0.073 -0.050 -0.051 -0.105
Recv:  3 -0.115 +0.043 +0.035 -0.091
4th try:
Recv:       0      1      2      3
Recv:  0 -0.061 +0.008 +0.018 -0.020
Recv:  1 -0.013 +0.002 -0.033 -0.073
Recv:  2 -0.068 -0.052 -0.063 -0.113
Recv:  3 -0.109 +0.036 +0.038 -0.100
Where can i look into?
Am i doing something wrong?
At Marlin git i read a lot that other with Marlin 2.x does might have problems with ABL too (Bug?).
I checked with M420 if leveling is activated after G29 - it is.
Yes, in my gcode G28 is followed by a G29.
I would like to use the whole print and didn’t expected such problems (searching since 3 days for a reason).
Its not my first printer (i do own Mk3, Cetus modified and an Hephestos with my own compiled Marlin 1.x).
Please help.
Joerg
Maybe its possible that others test something like that too? (even described earlier)
Posted : 04/01/2020 5:24 pm
Mike
 Mike
(@mike-38)
OP here. u-bolts checked and are not too tight. Also released the MINDA cable from the ziptie, just in case. No change.
I, too, and suspicious of the marlin auto bed leveling. I will run the mesh bed visualizer and report back if it gives inconsistent measurements.
Posted : 06/01/2020 2:16 am
ekkilein
(@ekkilein)
Posted by: @mike-m13
Do you have any news or improvements. I am struggling a lot - even after nyloc hack. ABL is compensating on the right more than on the left. Resulting in to high on right.
Posted : 10/01/2020 8:32 pm
Mike
 Mike
(@mike-38)
@joerg-e
Unfortunately I have had to set the project aside. I am out of time I can donate to the Prusa QA department. Will try again in a month or so. Back to my MK3S for now!
Posted : 10/01/2020 9:05 pm
dtackgrounded
(@dtackgrounded-2)
Have you seen this post on Github regarding Minda probe warm up?
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/72
Posted : 10/01/2020 9:55 pm
unknwnrider
(@unknwnrider)
After taking my mini apart to fix a different issue, while reassembling I noticed that if the Z axis is tilted even slightly, it can have a big impact on side to side and front to back height differences.
the 3 screws that hold the Z/X to the Y axis have to be adjusted properly to make things square. Even then you may have to shim the electronics box to make everything parallel.
I also found that the hot end cable bundle was too short. When the extruder moved far left it was causing the nozzle to “lift” away from the bed. You can test this by powering off the machine and moving your extruder far left. If it holds on its own, your cable bundle is ok. If it moves back towards the Z axis slightly, your bundle is too short. You can correct this by cutting the 3 zip ties on the Z axis and readjusting the cable bundle.
hope this helps
Posted : 11/01/2020 2:02 am
ekkilein
(@ekkilein)
Posted by: @dtackgrounded-1
No. Didn't saw that. But very interesting information. Thanks for the hint.
Will check that myself the next day.
Posted : 11/01/2020 7:57 pm
ekkilein
(@ekkilein)
Posted by: @jeremy-z
hope this helps
Today i bought  an digital spirit level and another tool to check the "squareness". Will check that tomorrow.
I already checked hot end cable etc. These are ok.
Thanks for your input and hints.
Posted : 11/01/2020 8:02 pm
Arklan
(@arklan)
similar problems here. I swear mesh bed leveling reads the state of the bed, but then when I run a print it doesn't appear to compensate. currently using the silicone bed leveling mod to try to bed flat, but having issues with one screw on the right never reading level, always wanting to be tighter...
Posted : 14/09/2020 10:01 pm
Hi Arklan,
Did you sort this by filing the Ubolt?
or is this still an issue
Posted : 15/09/2020 10:06 am
Arklan
(@arklan)
yea, that fixed it.
though it still seems the hotend isn't compensating for the small variance in the bed level the probe picks up.
Posted : 15/09/2020 6:08 pm
bobc
 bobc
(@bobc)
I've noticed the bed leveling doesn't do a great job with my bed. I can see the Z moving to compensate depending on the position on the bed, but the first layer still is somewhat uneven.
I suspect there is a sampling error, I'm not sure what algorithm is used in the Mini firmware, but it may not be sufficient to map peaks and troughs. The general rule of sampling is you need at least twice as many samples as the highest frequency.
I've never seen anyone do a proper calibration of the mesh bed leveling. You would need to compare the result with an accurate measurement by something like a dial gauge.
Posted : 19/09/2020 8:49 am
Page 1 / 2
