2nd layer over and under extruding
so this just started to happen today
prusa pla setting
1st layer is going down great
the 2nd layer and the layers after are having big globs in spots and the under extrusion in other spots.
i ran this print to see what the top layers would look like and it was the same as the 2nd (and up)
looks like the same pattern happening in the same spot on different prints ive tried. could it be the bed? i was thinking the minda is bad?
i printed probably 20 prints without any issue this started out of nowhere. my machine is only about 3 weeks old
RE: 2nd layer over and under extruding
I saw the same with my printer. Seems many are seeing it as there are many threads here about it. Try increasing print temp to 220 or 225.
Dont forget to clean the feeder gear.
Also this video I have seen and now used the fix in:
I had exactly the same problem, and the exact same fix worked for me as well!
