Comment décoller une pièce dans le slicer
Bonjour, j'ai l'option "déposer" activée par défaut pour tous les morceaux que je peux ajouter et je ne peux déplacer aucun morceau vers le haut. Je n'ai pas trouvé comment désactiver cette option. Quelqu'un a une idée?
Merci.
Best Answer by JoanTabb:
Good afternoon,
Please ignore any grammatical errors, I am using a translator.
If you saved the parts from your 3D package, in the correct orientation, the relative position information should be saved with the parts.
when you come to load them into Prusa Slicer, they should be able to retain those relationships.
If you load the part which touches the build plate, first, then Right click on that part and choose "Add Part" then "load"
and you can add additional parts to a model. these parts should self locate, if they have retained their relationship details,
If not, you should be able to click on the part that needs moving in the right hand window, and then move it up, down, left, right, rotate, or tilt it as required to muve it around the build plate.
ALIN I have added a Zip File, with two files in it,
Please download and unzip this file,
there are two STL's within the file called "ALIN" and "Aback"
If you first load "Aback" into Prusa slicer, then Right click on the name tag, which should appear on your slicer Plater ( in editor view)
then you should be able to choose Add Part>Load>"ALIN" and press enter,
and the name Lin, should appear on the top of the name tag. as expected.
If you just load both parts, together, then "Lin" will be placed on the plater, underneath the name tag back plate.... (Which is probably what has been happening when you have tried before)
Bon après-midi,Veuillez ignorer les erreurs grammaticales, j'utilise un traducteur.
Si vous avez enregistré les pièces à partir de votre package 3D, dans l'orientation correcte, les informations de position relative doivent être enregistrées avec les pièces.lorsque vous venez les charger dans Prusa Slicer, ils devraient pouvoir conserver ces relations.
Si vous chargez la pièce qui touche la plaque de construction, faites d'abord un clic droit sur cette pièce et choisissez "Ajouter une pièce", puis "charger"et vous pouvez ajouter des pièces supplémentaires à un modèle. ces parties doivent se localiser d'elles-mêmes, si elles ont conservé leurs détails de relation,Sinon, vous devriez pouvoir cliquer sur la pièce qui doit être déplacée dans la fenêtre de droite, puis la déplacer vers le haut, le bas, la gauche, la droite, la faire pivoter ou l'incliner selon les besoins pour la déplacer autour de la plaque de construction.
ALIN J'ai ajouté un fichier Zip, avec deux fichiers dedans,Veuillez télécharger et décompresser ce fichier,
il y a deux STL dans le fichier appelés "ALIN" et "Aback"
Si vous chargez d'abord "Aback" dans Prusa slicer, puis faites un clic droit sur l'étiquette de nom, qui devrait apparaître sur votre slicer Plater (en mode éditeur)alors vous devriez pouvoir choisir Ajouter une pièce> Charger> "ALIN" et appuyer sur Entrée,et le nom Lin, doivent apparaître en haut de l'étiquette de nom. comme prévu.
Si vous chargez simplement les deux pièces, ensemble, alors "Lin" sera placé sur le plateau, sous la plaque arrière de l'étiquette de nom... (Ce qui est probablement ce qui s'est passé lorsque vous avez essayé auparavant)
Cordialement Joan
RE: Comment décoller une pièce dans le slicer
Je n'ai pas trouvé d'option qui le permette non plus 🙁
Quel est le but de ta manoeuvre?
Bonjour,
D'après ce que j'ai compris, il n'est pas possible dans PrusaSlicer de positionner une pièce "en l'air". Tout simplement car il n'est pas possible d'imprimer "en l'air". D'autres trancheurs proposent cette option, pour ceux qui veulent imprimer sur un support pré existant.
Pour un modèle j'ai plusieurs morceaux qui s'emboitent et l'un d'eux doit être surélevé au milieu des autres. Mais ça ne marche pas puisque je ne peux pas lever ce morceau.
Good afternoon,
Cordialement Joan
Merci beaucoup, ça fonctionne! Si je charge les 2 indépendamment par import je ne peux rien monter mais si j'utilise l'option d'ajout d'une pièce je peux modifier la hauteur des 2 pièces. 👍
